LB7: Head studs vs factory
madmax02
Apr 30, 2012
88
Taylor, Mi
Obviously arp's are superior to factory bolts, but in reality how good are the factory bolts? About how much power do you have to start worrying about the factories not holding anymore?
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Hard to say as early LB7's have blown head gaskets stock. I'd say 500 plus running a larger turbo or twins I would go ARP.
5,812
in your truck, you will bend rods before stretching a bolt if you run good tuning and lots of air. as long as you keep that stock charger by its self and dont get into NOS, you will be just fine with stock headstuds and stock rods.
if you pop a gasket, it wasnt due to power, it was more than likely due to you having the older style gaskets in there and they would still go one way or the other
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
ding ding ding
Most HG failures are due to the older style gaskets, NOT the bolts stretching.
I am doing a budget build and LLY conversion and am not going to use studs, but I will be using the newer C grade gaskets.
madmax02
Apr 30, 2012
88
Taylor, Mi
So if I go with a larger charger I should be ok as long as I'm not building huge power? I understand that the early lb7's hg issue is because of the gasket.
paint94979
Beer Nazi
Sep 18, 2006
11,715
ding ding ding
Wow wow wow Jordan you're pulling your engine and not doing head studs IIRC I pay like 400$ for a set why not do them in your setup?
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Its a DD not a race truck. I havent pulled my motor I have a spare LLY. I just want a fresh motor with more oil pressure and not a shitty injection system. I will probably do a small set of twins and enjoy it as a DD/tow vehicle. I have talked to a few engine builders and for what I am doing studs are unnecessary. I will squish a rod far before I lift the heads.
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
What are your plans for the "more oil pressure"?
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
There ain't no way. I got all my motor parts cheap as dirt. I don't recall exactly what my price was in studs, but I believe 530-550. There isn't much mark up in studs from arp. Whatever I paid I think I only got like 10 bucks off retail.
Sent from my PC36100 using Tapatalk
