Head Gasket P/N's
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Type C - Thickest "normal" gasket
97309561 Right
97309258 Left
Type A - Thinnest "normal" gasket
98030631
98030628
Block Over-Bored .030" and Deck Milled .008" - The thickest OEM Dmax gasket, .010" thicker than a C.
97358466 Left
97358465 Right
Block Over-Bored .030 and C thick.
97358467
97358468
dieselson
1,544
30
Huntington Beach, CA
Hey kathy, head gaskets and stud information at the same time, you must be thinking of us :) We will do this eventually, it looks like the head gaskets might not be bad, because the leaking has stopped.
Lennart
Not from here !
Aug 10, 2006
305
Detmold, Germany
ASSuming I wanted to lower the compression by just changing gaskets, how much volume would I gain (how much could I lower the CR) by installing the 0.030 over and 0.010 thicker than C?
SBCNX20
Junior Member
Aug 7, 2006
354
53
Central MA
You dont want a 30 over gasket in there with stock bore . That leave space for combustion pressure in a very tight (the gap between head and deck) area and will cause some hot spots around the cylinder.
