Has the DMax been dethroned ?
726
Not the way I read it. I don't think the big turbo feeds into the small turbo. They both feed into the intake manifold seperately. See picture below.
hmm looks like a parrealle setup that is tryign to function as a single setup minus the lag of a big single or the high boost of a compound
13,765
834
Yep, you have to remember this type of setup is typically used on gasser cars that can't handle the big boost of a compound setup, but don't really have the displacement to spool a big single by itself at low RPMs.
Here's some more info on flow and stuff: http://www.max-boost.co.uk/max-boost/supra/turbo.htm
13,765
834
Doesn't look to me like the big turbo is feeding into the smaller one.
13,765
834
Kinda hard to tell what they have going on with the exhaust flow. They may have something going on that can't be seen in those pictures, or it may be a VGT that opens up all the way until the secondary turbo is supposed to come in. I think you would need to see one in person to really tell if it is a compound or sequential setup. The compressor side is what is going to determine if it is a compound setup. I have never seen one before. That's why I was asking what it was.
maine04max
Dec 11, 2008
1,009
on the specs section it shows 1 turbo as low pressure and 2nd as high pressure. does this make it compound??????
726
only if the low press turbo feed the high pressure turbo.
a sequential has the same a LP turbo and a HP turbo as a compound does. the bigest difference it the airflow from either turbo doese not pass through the other on the intake or exhaust in a series.
726
got this from Direct Injection Performance (psd player)
picture.php
this help josh :hug: :D
15,681
235
I think the late Fords have allways been able to make big power. The question is for how long.
juddski88
Freedom Diesel
Jul 1, 2008
4,658
128
Chesterfield, Mass.
is it just me or does that turbo system look like a waste of energy? it's almost like that "tornado" piece on Ebay that increases MPG by 30% by creating a vortex :spit:, only more expensive
13,765
834
picture.php
Based on that picture it looks like a compound setup. What's the big thing where the intake air paths cross? Also, it almost looks like the turbo that is second in line is the bigger charger. But I'm just going by what I can see of the exhaust housings since it's hard to tell what they have on the compressor side. I really wish I could see one in person and hold it in my hands.
The only thing that really confuses me is that Ford is calling it sequential turbocharging. I think they probably know the difference, but who knows.
726
it has a rod that goes to the VGT/VVT to adjust them.
Catipiler does the same thing.
Utahski
Oct 20, 2008
546
Northern Utah
Several times I've seen those things referred to as "compound" turbos. A couple other places called them "sequential." What looks like a Ford release also says they're sequential, so that's what they must be. And still a couple other places including an article, referred to them as "compound sequential." All the stupid bickering and so what?......who gives a damn what they're called. They're twin turbos.
