Has the DMax been dethroned ?
A_T_Ver
416
Not my fault ford makes a heavy truck. Hell i wish them luck in competition being it drag racing, sled pulling, and what not.
TIM Z
Screwed by 0087s
Jan 17, 2009
1,574
Navarre, OH
I agree, Im Glad to see Ford Doing Better.
I WANT The Big Three to Succeed, Its what America needs.
No , I will Never own a Ford.:spit:
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Dyno sheet just proved wrong what you just said. They have a frame mounted lift pump just like the 6.0's ;)
brian I was answering Rich's original question.........I guess what I should have said was "nope, no way you are going to do 600rwhp [on a duramax with a] a stock trans and no lift pump
KEVINL
1,431
Phoenix, AZ
I say bring it on
I still think the 6.4 is junk
Will see how many are making 600hp at 150,000 plus miles
It is nice to see them finally run some decent times though.
I would never own a truck I have to pull the cab to work on
SBCNX20
Junior Member
Aug 7, 2006
354
53
Central MA
Staying together????????? Jason (1BADMAX) never did answer the question as to what happened to his tow rig [2008 F-550] with under 20k on it and stock everything.
http://208.109.104.11/forum/showpost.php?p=199544&postcount=1
BOOM it broke a rod not 20 miles from his house on his way to Lebanon Valley so he did what any true racer would do........ unloaded the "race truck" and drove it the 100 miles to the track!!
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
Who do we get to laugh at now?
The guys that are still trying to make their 6.0 fast:rofl:
Or we can all just ban together and laugh at guys that buy fullsize gas trucks - especially 3/4 ton or bigger trucks. Then again I laugh at people that buy gas powered anything since my Fiance's TDI Jetta gets better mileage than a Prius and isn't nearly as gay.
bigbird
837
Edmonton, Alberta, Canada
Like this one.
[YOUTUBE]qQNNhRqRS1g[/YOUTUBE]
This is a good friends truck. He had a horrible launch 2.2 60 ft. normally 1.6x's
124mph in a 8000lb truck is 1000hp on the calculator. He dynoed 1004
:witch: edit to make purty video :D
05' Ditry Duramax
May 3, 2008
1,294
42
Port Orchard Washington
Good point!!:rofl::rofl::rofl:
I had a guy telling me his Hemi 3/4 ton Didge was walking around all these diesel powered trucks going up mountains and stuff. I laughed right at him and he thought I was laughing with him.:rofl::rofl:
blownblue
Oct 22, 2008
61
Acme, WA
Nice to see them make power, I will stick with the dmax. Had a ford and ran strong for a while then slowly started falling apart which got old.
othrgrl
Mar 10, 2008
2,151
Wilmington NC
Like this one.
Didn't say it couldn't be done, it's just not nearly as common as doing it in a DMax or Cummins and it still won't run with a 1000hp DMax.
Utahski
Oct 20, 2008
546
Northern Utah
What say you ? Can a DMax do this on these mods ?
08 6.4 Super Duty. Spartan tune, DPF delete, intake...nothing else.
There's actually a throne? That 6.4 is a compound turbo engine with big tune, an intake, no dpf, and was dyno'd in Michigan(?) at sea level or very close to it.
Compound turbos to compound turbos........A few years ago Idaho Rob's LLY with the same kind of setup......twin turbos, an intake (part of the twin kit) and his tune, was making at least that much power at 2600' elevation and running about 12 flat. Now, his stock '07 LBZ with same twin turbo setup and his tune.....makes well over 600hp and was running high 11's/12.0 at that same elevation before the bigger injectors. Nathan's LMM is stock except for twin turbos (like the Ford), has Rob's tune, DPF delete, and also makes at least that much power....he'll be in the 11's before much longer. Again, these guys are at 2600' elevation.
