GT4202 vs. S474
KEVINL
1,431
Phoenix, AZ
does the 4202 spool noticeably slower than a 4202R
how does it compare spoolwise with a 4094R
JOHNBOY
< Rocking the Big Single!
Aug 30, 2006
2,159
Saegertown, Pa
The difference between the 4202 and the 4202R is not much. I personally think ballbearings are overated spool up wise.
I am not a fan of the 4094. It is laggy no matter what you do. I actually thing the 4294 spools better.
MaxPowerLB7
Amateur
Nov 8, 2007
623
40
Spanish Fork, UT
IMO the only difference between a journal and ball bearing is the price. Having said that i haven't run a ball bearing. My engine build budget was getting slim when i was getting a turbo so i got the cheapest 4202 out there. Was planning on getting a BB.
The 4202 doesn't have incredibly high drive pressure. Mine is around 46:73 boost to drive pressure.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
FWIW, my S472 is almost 1:1 boost to drive pressure.
If you were on dual C's it would be more , it isnt too hard to keep drive pressure in check with most decent sized turbo's until you start pushing them up in there map and running big power/ making big boost Just an FYI .
Nick if the price is the same between the two turbo's which it sounds like it is then i would choose the GT4202,Most choose Borg over Garrett because of cost , not because we think they are better .
