Those pics give me deja vu ... :baby:
no one has anything else to add?
will it be used on a stock charger truck or something like a 4094avnt?
do you have a drive pressure gauge yet, you know the drive pressure can be managed pretty easily with the vane tablesto get rid of insane excess drive pressure as a single or to help more exhaust flow to the low pressure in a twin setup...
im sure it can be helped but i dont think it will ever be where i want it to be (probably not even with wastegates) but anyway this will open a whole new world of tuning up...
who knows what vane% these turbos really like? no one has found out because they'll overboost. now with gates i could run 90% vane all the time and still not overspeed/boost.
90% probably wont be the way to go but you get the idea:cool2:
Why would it never be where you want it to be even with gates ? If you setup the gates right there should be enough flow to almost snuff the charger , DP will not be an issue with the a waste gate installed trust me , the real question is what HP gains can be had .................... if any :baby: , and BTW there is no need for 2 gates other than if you dont want to hassle with plumbing it for just 1 .
just due to the efficiency factor of the turbo... do you think the turbne is efficient enough to create boost at near a 1:1 ratio if no excess gas was present?
im kinda doubtful on it but maybe...
and why only one? wouldn't that create unequal pressure on one side of the motor?
