Ok so here is the story. Truck is an 06 LBZ. Has Suncoast trans with 1058. EPR 366 with HSP 3" bridge and tube, stock injectors, AirDog2 165, factory filter head, EGR delete, PCV reroute, EFILive by Kory, 5" turbo back exhaust.
The truck on Dec. 1, 2013 overheated the trans to 280*, I limped the truck 75 miles with trailer in tow to within 30 miles of home when she stopped shifting. I pulled over and called a tow. Fast forward 2 months and the truck had the trans pulled. Trans was rebuilt by myself using suncoast parts and got a 1058 converter. The stock turbo was removed and a EPR 366 kit put in with a bw s366. 66 comp, 80 turbine, .91 a/r on a t4. I installed the transmission on April 12, 2014. Turbo was installed on April 16, 2014. I got the truck started April 17, 2014 and had a small issue with the valve body. Thanks to a member on here we got it all squared away and the transmission was happy and no codes.
So go to take it for a drive and it threw a P0101 code and I also noticed that I could not get fuel past 15k and it was more or less cutting fuel at 1600 rpm and slowly getting up to 1900rpm. Back off the throttle a touch and it would shift nice and smooth. So I checked the size of the intake and it was slightly smaller at 3.8". Kory tweaked the tune and code goes away but the truck still wont fuel.
I have cleaned the MAF sensor, tried to flip it around (ya never know how something small could bite you in the ass) but it will only go in one direction...diodes towards filter. I have changed all 3 fuel filters after maybe 20 miles on them. I have unplugged the FPR and started the truck only to achieve 15k rail psi and then truck sounds like its against a rev limiter. I did the bottle test this morning and I gave her all she would try for and got nothing in the bottle.
When I go WOT it will jump rail pressure to 18k psi and rpm to 2100 and then fall on its face. Rail goes to 13k and rpm to 1600 and acts like its stuck in gear.
I have sent multiple logs to Kory and he being the awesome guy that he is has sent me 4 different tunes to try, none of which seem to be fixing the fueling.
Im lost now at what else to try so I humbly ask for assistance. Thank you in advance.
