Fuel distribution block
9,905
151
This is what Trent and Simon did on their trucks.
The blue tube was from Summit I believe and the aluminum return is just a shop air press manifold. Along with custom built braided stainless lines. All in all I think it was under $300 CDN for everything.
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
lol I had about 100 in mine....it wasn't pretty but it worked perfectly and was safe.
I had a little more than that but not by much. Distribution blocks off eBay. Pushlok fittings and hose from jegs. My CP3 Y feed fitting was a 1/2" NOS brand fitting :D
sickdiesel
Apr 22, 2010
1,019
only real sensor on the whole supply and return lines (low pressure) is the fuel temp in the return line next to the turbo
jpowel29
780
Bentonville, Arkansas
Going to try this setup. I may add the fuel temp sender on one of the open ports. Moroso fuel block with built in pressure regulator and gauge port. Running the returns back to the cell through an old school Mr Gasket chrome fuel block.
MAXX IT OUT
Neglected
Mar 1, 2013
1,781
Des Moines, Iowa
bringing this post back up. Any one have any new pics of fuel distribution blocks?
This first picture is how I did mine, I got the block from Granger for like 20 bucks. This other picture is rgullett83set up, I wish mine was that way, but I didn't have the Van T-Stat housing on at the time or mine would be mounted in the same place.
rgullett83
1,607
Illinois
The 2nd pic is mine, and that is my return side. As far as supply goes, I mounted a y- block on my fire wall. It is a -10 inlet, and -8 outlets going right to the cp3's.
LbzDMax07
179
PA
How do you have them Connected to the cp3 pumps? Barb fittings or an maybe
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I used all AN fittings. -10 from fuel cell to bypass regulator, than split into -8 to the CP3's. Return lines are all -6 into a manifold block, than -8 return line from the return block back to the fuel cell.
