Problems may arise with wrist pin bushings, piston integrity and so on. I don't know Simon, do you think a gasket will fix it? What is the thickest gasket available?
With the clearance issue and all the other past thread mentions, the confidence level is not there. It will take someone going through the engine top to bottom and then....
I think but could be wrong that most people use a stock wristpin?
I dont know to be honest i just know that is what i used.
I learned the hard way to check the protusion of the pistons when doing a build,Some guys think that is a "No Brainer" I on the other hand ASSUMED it was good.And i was lucky to not do more damage. im sure if i would of reved any higher than I did my pictures would of been the same as Micks
<HR style="COLOR: #d1d1e1; BACKGROUND-COLOR: #d1d1e1" SIZE=1> <!-- / icon and title --><!-- message -->
Gasket Grade..................Compressed
Gasket Thickness
A............................0.0354-0.0394
B............................0.0374-0.0413
C............................0.0394-0.0433
2 other gaskets listed in service manual
Block Over-Bored 0.010-0.030 in ...............0.0394-0.0433
Block Over-Bored 0.010-0.030 in and Deck Milled 0.008 in....0.0492-0.0532
What kind of Pistons are they?
