forward facing t-stat housing hose options
redws6rocket
406
Odessa, MO
not the best picture, but that is mine. g van housing and hose, my tcm is mounted in the battery tray. factory tcm cover must be removed and drill holes and mount tcm to fan shroud is what we did on a friends. hose will set up on the fan shroud, we cut my shroud some to let the house set in it some.
05chevy
1,086
Here is mine. Everything off a 06 van
ikeG
Oughta Know Better
Apr 19, 2011
2,464
147
Western PA
www.facebook.com
Talked to PPE today, and they have just started selling a dual fueler belt that will clear their oil centrifuge. Its not listed on their website yet. I ordered one, assuming this will work great with dual pumps and the van thermostat housing/hose. You will have to retain a/c compressor or the delete pulley. Hoping this works for us, I will update after I get er done.
TRUBBS
461
sub'd also
i havent ever really looked closely but when running the van housing, how do you feed the turbo coolant? or is that not directly tied into the t stat housing like im thinking?
13,712
773
sub'd also
There is a spot on the housing to hook up the hose.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I just bought a van housing. I heard the bolt pattern was different too so went with what I knew would work. I do wish the van housing had a burp bolt, but not a huge deal
ikeG
Oughta Know Better
Apr 19, 2011
2,464
147
Western PA
www.facebook.com
If you run a van thermostat housing with dual pumps you will need a longer belt and route it differently so the belt clears the van housing. I used a Dayco belt that I bought from PPE; its the one they use when running dual pumps and their oil centrifuge. If I knew the part # ahead of time, I could of just got it from local parts store. PPE tells you to look at the pictures on their website for belt routing reference, but I fought with them today about it cuz their pictures do not have the belt routed the correct way.(with centrifuge and dual pump) Let me know if you need the info.
kjp800
Aug 6, 2008
525
New Jersey
I ordered the van housing as well, prices were real close so why risk it not lining up.
I had to reroute the belt too, found a Dayco through Grainger, although not sure if its the same as PPE has it, I played with the idlers some so the turbo could mount how I wanted it to off the front of the block
