First off, the only dumb question is one that is not asked....
In a CR system you have three things in a givin injection event that matter.
Timing
Duration
Fuel pressure
in that order is how the fuel is delivered,
Timing is when the fuel startes out of the nozzel, duration is how long it fuels, and fuel pressure is how much pressure is sustained during the whole injection event, this one is by far the most important, because it ensures atomization, thats what make the fuel most potent when air is introduced.
Would you back off timing at 80 psi. with a big turbo? With no nos. Jeff
Does the flame front travel to the piston faster with nitrous? If this is the case, then I can understand backing of the timing.........Right?
How do you hydrolic with air. Its the same fuel amount. Jeff
Why would nos air burn faster than boosted air? Not because a reason. Jeff
So a water to air intercooler you would run lower timing? It would run alot cooler than nos in a short burst like a drag race.
your still not telling me why it would burn faster with nos. I need a reason, Not because everyone thinks so. I want to learn but nobody can give me a reason why it would burn faster in a diesel. Jeff
Here's how it works:
As the piston comes up higher and higher, the temperature of the air in the cylinder increases, but the head and walls are cooling it down, so it's not exact. Starting about when the air is ~900 F, you can begin to shoot fuel into it. If you shoot it in too fast, the fuel will actually cool the air back down too much, and bursting happens, which is "unstart", and the fuel just vaporizes into a white gas and exits the tailpipe unburned.
But if it does light, the injector continues to spray fuel in as the piston travels upwards and the pressure rises. But diesel burns slow relatively speaking, and most the fuel isn't even in the cylinder yet, so the peak pressure hasn't occurred yet. The pressure peak happens shortly after TDC (~3 deg). But the piston cannot really push very hard to rotate the crank, since the crank is nearly straight up. It's only when the piston is way past TDC that it has any "leverage" to push down with and spin the engine. So it's the pressure that is "contained" in the cylinder doing the work, the peak pressure is just a necessary evil that bends rods and cracks pistons.
When you have nitrous in the mix, it's first thing is that it makes bursting happen earlier since it cools the air down, hence the wild nitrous backfires and unstarts you see sometimes with it. The peak pressure is always going to be very close to TDC, but you should always keep after TDC if possible or you lose power. Since nitrous makes the pressure rise faster, pushing 4 degs or so is hopefully going to keep it ATDC, and reduce the odds of bursting/unstart.
IMO...
I guess I will agree to disagree. diesel power my inlet temp are never that high! Your's shouldn't be. Pat I still do not see how in a boosted condition that there is a difference. Will it burn hotter? Yep! But it still doesn't change the burn rate. Jeff
turbo outlet temps are very high sometimes, that is where i inject my nos at, right before the IC, see there is a lot of tricks to makeing nos work for you.
the burn rate should increase because the oxygen consentration increased...more oxygen- more power!..........to a point
