Firestone Airsprings for the front ???
B1 596
Dmax rods cost how much..
Apr 30, 2010
52
Hudson N.H.
Anyone use the firestone Airsprings for the front ? Its a Bilstein shock with a Firestone air spring on top , anyone had any experiance with them ?
Thanks Pete
FordTechChase
PowerStroke Tech
Aug 7, 2011
McAlester OK
I seen this on a F350 a few weeks ago. A customer had this on his truck when he brought it into the shop. What is the purpose of it on the front? On his I think it was a cheap way out of replacing his worn out arse leafs on the front.
Atouchofgrass
Jun 19, 2010
526
Pretty sure they soften the ride along with having the versatility of being able to run a plow without any issues of sagging. Overall a great product if you have the use. I was thinking about purchasing a set.
2DMaxx
May 27, 2011
50
long island
I'd say that too...It would be for a plow , thought of them for my truck too...If anyone else has them please let me know...
B1 596
Apr 30, 2010
52
Hudson N.H.
Yea I think they would be great and appreciate the replys but does anyone have em on a truck ? The ability to adjust for a plow , ride quailty and handling make these seem to good to be true .
Dozerboy
4,892
470
TX of course
I thing you would need to re engineer the lower shock mount on our trucks to take the abuse an "air shock" would put on it.
titch--
Jul 10, 2011
5
Im going to be ordering a pair of these Firestone Level Rite #1003 here soon for my truck, as Im putting a blade on my truck for the winter and this looks to be the best answer for the front end suspension.
N2BRK
2,054
371
I'm thinking that although you can change the front ride height, you'd have to keep the front at the exact ride height as when you were last aligned, right?
titch--
Jul 10, 2011
5
Are these shocks normal height? Like what I mean is if I wanted to level my truck from stock height would I need the shock extending mounts with these shocks to raise the front 2 inches?
BlkMax
743
Wasilla, AK
Be careful if you use these for plowing. I had air shocks on an older truck and they ended up breaking. Water from the air system froze in the shock body. They work for warm weather, but you have to have really dry air when used in the cold.
Having said that, I have not used them on my truck, and can't comment on the ride, etc.
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
Whats everyones opinion on how much they would stiffen the ride of a truck with lowered torsion bars to compensate for the softened ride from pressure being let off of the torsion key? Would they help prevent body roll? Also how much does one of these setups cost?
B1 596
Apr 30, 2010
52
Hudson N.H.
Best price seen so far is $ 480 shipped . Has anyone seen them cheaper ? Almost ready to pull the pin on these things
