Well some know I've started a build got my block back on Monday and hoping to get the short block together then jerk my motor to get the heads rebuit and screw in cups and decked then start swapping.
Now my questions I think im going to get a new oil pump mines working just fine just figured id put one in as I've seen it suggested to do so. Does it need pinned or keyed? My overall hp goal is 750-850 so I'm not going extreme extreme but want to be safe also going a new water pump. Anything else I should replace
Build consist of...
Carrillos
Mahles race cast pistons 16.8:1 .020''
Main Studs
screw in cups (II)
Clevite h bearings
new cam bearings
rebuilding the heads new valve guides ect
new oil pump
new water pump
already have
ARP studs
Dual fuelers with a (II) modded pump
366/480 turbos (still need to build piping)
45% over (going to 60 or 100 overs)
Ive been thinking on manifolds and up pipes or at least a lml manifold ill post some pics when I get some good ones
anything im forgetting guys?
Build consist of...
Carrillos
Main Studs
screw in cups (II)
Clevite h bearings
new cam bearings
new oil pump
new water pump
already have
ARP studs
