Favorite tool thread
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Nut I made. Slips up past splines on pitman arm to engage threads, also has shoulder to fit my cognitive brace. Basically this thing engages all the threads on the shaft, whereas the old nut only engaged .275 or so
13,736
806
I can make one.
PM me a price. I have no idea how much the material or machine time, not to mention your time, costs, but I'm interested in getting one if they aren't too expensive.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
30 bucks shipped
Do you have a way to enlarge your cognito brace hole? I had to drill mine out to 1.125, that way it ensured the nut had .100 wall thickness for threads. If that makes sense. If you can't, ship me yours and I'll do it. And for anyone else I need to know if you plan on running the braces because that changes things a little.
Waid
Skeans1
May 14, 2010
3
Been a while since I've posted here but here it is my saws and tree jack. Jared
395xpw with a 60" cannon bar buried in a large cedar.
372xw with a 32" sugihara bar.
250' 2nd growth Doug Fir with a lean back over a property line.
562xpw 32" bar
385xpw with a 32" in a large Doug fir.
onebaddmaxxx
1,212
Cecil County Md
I actually added another to the favorite tool list. To anyone who has ever done a track bar balljoint on a superduty ford knows EXTREMELY pain is the a$$ they are. A normal balljoint service kit does not have a wide enough mouth to service this joint, and beating it out can be pretty tiring. This kit retails for high $7xx's and caught it on sale a few weeks ago for $625 so i decided to get it as im growing bigger in a shop. It fit perfect, has clips that hold all the adapters in place, and took longer to figure out which adapter to use than it did to press the old one out. Absolute must have for front end work
Llyduckhunter
40
35
Iowa
I have that same press. One of the best tools I have boughten.
Awenta
4,090
CT
The titanium IR guns are nice. Enjoy it!
DURAMXD
BOB SAGET!
Apr 24, 2012
348
Wichita, KS
Two newer tools I've picked up recently, that turned out to be definitely worth the money.
First one is a set of ratcheting hose clamp pliers. Pretty self explanatory but very awesome for the factory GM coolant hose clamps.
Second one is a tap extractor. I was tapping holes on the side of a block for an HSP twin kit mount this weekend and broke a tap off below flush in the side of the block. Called my Snap On guy to go warranty the tap and he showed me the tap extractor. I'd never seen one before. The little fingers go down into the flutes of the tap and then you cinch the collar down and thread it back out. Needless to say, it saved my ass.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
No more frustrating straight blade screwdriver to remove push pins, could have used them when I replaced the radiator bushings on the Wife's Honda CRV. Had to remove the front fascia and Honda is generous with the push pins. I can get to all the fender liner pins on my truck and not have to turn the tires....
Straight, 45 and 90 SES819KIT
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
My favorite tools aren't mine, but they are literally push pin pliers and hose clamp pliers lmao both snap on. But my most favorite is probably my stainless credit card bottle opener, don't get much done without that:spit:
