Fan removal tool
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
This. Tried the tension strap and crescent... wouldn't hold it tight enough to break the nut loose. Took about 30 secs with this ..... $60 for one time use though.:rolleyes:
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Here?
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
No the tool goes into holes on the front of the pully, put the groove of the tool around the nut, tabs towards the pully, then use a wrench on the nutand the tool to hold the pully to remove the fan!!
s3gulit
Teh Farmer
Dec 6, 2008
173
Illinois
took a peg board hook, bent another end, slid it into the pull, took a prybar and wedge it between the pulleys and had to give the nut a little bit of heat to come loose but it was simple and all i use was about 15cents of gas on the little torch and a 25cent pegboard hook.
whitetrash21
Apr 29, 2008
4,929
Vegas
What he said.... you need it, I can send it... Let me know.
Bentley
Doesn't know $hit...
Mar 7, 2008
193
Under a big a$$ rock...
My tool of choice its and air chisel. All you gotta do it bust it loose and it comes right off!
Look what the cat dragged in. :D You still alive?
Yeah well...
I just got a 24" long flat chisel for my air hammer... No more fighting to get it in position and it takes 2 seconds to bust her loose I will never take a clutch fan off with out it ever again!!!
SDP
AKA Dmax15
Dec 20, 2008
261
Port Angeles, WA
I just used a big crescent wrench and a small 12" adjustable spanner and it broke it loose, first time its come off at 100k.
Turbotug
BEER SLAYER
Sep 3, 2006
1,019
46
Phoenix
You are not beating the hell out of it. Not even close.
Seriously, it was a couple easy pops and it was loose. You only have to move it like 1/20 of a turn before you can spin it off by hand.
