Factory frame coating removal
motoking_1990
1,957
5
Terre Haute, IN
Did you use anything to clean the frame after you got the rust and wax off?
I got most of the thick parts off with the paint scraper. After there was a really thin layer I used the sea foam and a rag and it took it right off. Wiped it dry then used the rust reformer. After it dried I did the final truck bed coat.
Jan 28, 2015
961
Ohio
Alright I'm in the process of doing mine and used air craft remover and a scraper. Bought some mineral spirits to wipe on after I get all the gunk off. Time consuming as I'm gonna rough it up with 80 grit sand paper. Have about 7 hours in mine so far and not even done yet.
motoking_1990
1,957
5
Terre Haute, IN
Time consuming is an understatement. Take your time and do it right the first time, don't want to have to do it again. Good luck!
Jan 28, 2015
961
Ohio
I'm in no hurry lol had the back half sand blasted and painted when I got my bed painted. Time to make the whole frame look good.:thumb:
minerigger
2,660
Casper, WY
You guys using the seafoam/diesel to remove the crap, then mineral spirits to clean for paint? Putting any primer down or just whatever you've got for paint?
motoking_1990
1,957
5
Terre Haute, IN
A rust reformer to stop the oxidation. It turns the rust into a paintable surface.
motoking_1990
1,957
5
Terre Haute, IN
Wheel wells in the bed need something. Not sure what I'm going to do there yet. Maybe the same thing idk. I hate taking my wheels off more than I have to.
Awenta
4,090
CT
Just need to paint the axle now. And you can get plastic liners for the rear wheel well.
motoking_1990
1,957
5
Terre Haute, IN
Axle is done as well. If I remember I will take a picture. Give a second I have to run out to the garage anyway. Have my exhaust tip soaking in diesel, need to check on it.
Dozerboy
4,918
497
TX of course
I used several coats of plastic dip on my front wheel wells 2years ago its holding up pretty good. Did my rears with rubber under coating 7years ago and it didn't hold up for shit. A little better prep would of helped, but still wouldn't of held up.
motoking_1990
1,957
5
Terre Haute, IN
Do the liners cover up into the wheel tubs? Or just the lower part and cover up the bed sides? Here is the axle.
Also I need to add to the exhaust topic, I have the mbrp exhaust......I hate it!! Ubolt typr Clamps, it sucks. Had to move some hangers to get the exhaust high enough to clear the axle. They had the axle bend over the pumpkin which left no room after I lowered.
motoking_1990
1,957
5
Terre Haute, IN
The rubber undercoating I can bluntly say is F***ing s**t!!! Prep or no prep. That's why I have been using the truck bed coating all these years. It's textured.
minerigger
2,660
Casper, WY
What did you use motoking? Spray on Bed liner? after cleaning with seafoam/diesel and using a rust reformer
motoking_1990
1,957
5
Terre Haute, IN
It's like 13 bucks a can I used about 6 or 7 cans on axle, frame, driveshaft. I haven't done the front wheel well frame area yet. I'm going to wait until next weekend when I do the key swap.
