Diesel and oil.... Might try that I just used oil thinned with mineral spirits so I could spray it on. To keep it black and keep the rust down.
.My truck is on its third winter and the frame is rust free. Works awesome.
I painted the frame on my LLY and I was constantly wore brushing it and touching it up.
Cleaning and repainting.I think the diesel cuts the oil so it can be sprayed.Are you going to clean and repaint the frame motorking or just cleaning?
I'm confused what does the oil and diesel do? Are you using it to take the coating off or protecting it? What did you use to coat it with?
Ahhh makes sense.I use it to keep the coating soft so it doesn't get hard and crack and peel and let salt and dirt under it.
I used straight diesel on my LLY and it turned the coating to water and it rolled right off.
How well did the oven cleaner work?I'm going through this now on my frame. First I painted the frame with diesel, then scraped it and got the bulk of it off. Then coated it with gasoline since that seemed to work better. The problem I was having would be it would just smear everywhere after it had been melted. So now I have the frame coated in oven cleaner and we will see how it turns out in the morning.
Biggest problem with mine is I have the frame plasti dipped so there was a shit load of rubber on the frame.
Just coated mine with oven cleaner. We will see if it will work
