Why do you think a run an LLY...QUOTE]
:blah: Your time is coming........
Or post them here and we are all more than happy to help!!![]()
Don't start with me Dale![]()
OK, I got the fuel balance rates recorded.
MIN AVG MAX
#1 -3.36 -2.9 -2.39
#2 -1.09 -0.8 -1.88
#3 -2.78 -2.25 -1.23
#4 -1.06 -0.70 -0.98
#5 -1.75 -1.13 -0.45
#6 -1.95 -1.58 -0.13
#7 -2.08 -2.54 -2.66
#8 -4.09 -4.64 -5.28
This data was taken with the engine temperature just above 160*. Looks like #8 is toast.
I would do a compression test to confirm if it is an injector or cylinder issue before you start ripping and tearing.
Just my two bits of advice!![]()
Negative balance rates indicate a piston is making too much power, and it is trying to pull fuel. .
Could be several different things. I'm no expert, but my guess would be injectors more than anything. If you're really worried you can move the injector and see if the balance rate problem moves or stays in the same cylinder.What do you do about that?
Compression check would be the best.....Even just pulling the glow plug
Where would it be coming from, Henry? I thought since they moved the injectors out from under the valve cover they didn't dump fuel into the oil pan when the injectors went bad.
Kenny's problem is weird because of all the blowby but not a lot of smoke coming out of the exhaust. My truck smoked like hell when I killed a piston. Looked like I was fogging mosquitoes.
