Yeah that is true, I deffinatley want the heads checked, they will most likely need work. Think I had a blown hg aswell
probably milling the decks too if its that bad from the hg. I know I have no trouble removing the heads, cp3, turbo, exhaust manifolds but past that I don't know what would need to be removed, water pump and stuff? Heres what I want hopefully this will help everyone understand what is going to happen..
So far what I gather from that is that I should take the heads off, send them the shortblock to start with there inspection, teardown.. bring them the heads also incase they need work (if they do I will just have them install the heads back on so I can save a trip going back there to insure I have it timed correctly)
list if what may go in it, this is hopefully gonna be pretty cheap. Please give me some insight as to anything else I may need, but only if it is a proven NEED..
lb7 cut pistons
head studs
carillos (if I get rods)
crank, cam, and wp keyway
