Even if it's not blocked I would let it be. Unless you plan on building the trans and going all out on the tuning it's probably not worth it. To remove it completely you have to replace the up pipe and change out the y bridge(or use the hsp style pipe that uses the factory y bridge). While not over complicated it is pretty time consuming if you have never done it before
