Eliminating knockdown with the Transgo valve
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
From what I've gathered by reading through some previous posts, I just have to remove the checkball and replace the spring with a longer one, is this correct?
15,681
It has to be long enough and strong enough to keep the valve seated till fluid stokes it. Make sure it has some heat treating so it doesn't calapse under heat or you will get uncontrolled TCC apply.
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
If I am unable to locate a spring, I will probably make a spacer to take the place of the checkball and re-use the transgo spring. It will basically be a .200 thick washer, with a hole in the center to eliminate the hydraulic force in the cavity where the checkball seats.......Should work, if I'm thinking about the operation of the valve correctly.
marc75
111
the spring company that made mine said it's good for 250* and they can make more resistant with another product. do im ok with them at 250* or im better to order more heat resistant ?? btw i have 100 of them if someone need some i can send by mail and i can send all the spec from the spring company by email
marc75
111
just ordered oil temp chrome silicon spring delivery if someone need that spring i ll have some in 3 weeks pm me if you want some
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
plug the end and cut a groove in the outer-most land parallel to the direction of travel. groove should only be 1/16" wide x 1/8" deep approx.
Tim
How do you plug the end of a later valve??.......;) What you described only works on the older style of valve used on the LB7's and some of the early LLY's as the later valves have no passage through the inside. They route oil through the separator plate to achieve essentially the same thing. If you look at a fluid schematic you will see what I am talking about.
15,681
Then why did Transgo put a check ball and spring in the valve in the late ones?
