Edelbrock Heads
13,736
805
Any idea why the Edelbrock exhaust ports flow so terribly at less than .300 lift? It's pure garbage down low. Almost half of what stock flows.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I do not, I do know there are some casting flaws that are definitely hurting flow. When I disassemble them to clean up the ports and bowls I will try and get some pictures of them.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
These are some of the imperfections I blended to help flow.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I opened up the exhaust ports a little to gasket match the exhaust gasket.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Removed some of the casting bump in the intake ports and radiused the inlet some. It’s by no means a professional port job, I just wanted to clean up the bowls and blend areas to flow a little better.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Zak, when do you think you will run them on the flow bench to see if/where the gains were made?
I will not be putting them back on the flow bench. Heads are bolted back on the motor already. I want to get motor back in the truck and get it finished up so I can move on to another project that got pushed back because of this truck...
