Will that Wagner intake work with a turbo in the normal position or is that for the twisted pedestal they offer
I think they recommend there twisted pedestal. I run a remote turbo mount.
What else needs to be done when installing a body lift? Like extending wiring, etc.
Zak,
Do you have a 4" lift also?
What body lift did you use?
Must be you have your heads shaved enough to make it a pain. My wagler intake dropped right in place real nice piece just hope its gains are enough to make it worth the $$Finally got my Wagler intake installed. Turned out to be kind of a PITA! I had to slot the bolts holes with a die grinder to be able to get the mounting bolts in. Not sure because my heads have been milled to much or intake machining off.
I'm sure you know its backwards..
Wonder if that makes a difference on the bolt hole alignment?
