Duramax VGT on a 6.7 powerstroke
1slowmax
The break is over
May 9, 2012
283
Sin City, NV
If anyone wants to mod a 6.7 Ford put some Carrillo rods in it first. They have TINY rods and a thin block from the factory. They cant hold much over 550-600hp.
BTW Carrillos retail $3900 for the 6.7L application.
gr8shot
Practically stock
Apr 28, 2009
262
Grand Island, NE
So how did h&s pull out over 800rwhp out of a 6.7 then? I've heard both sides of the story, that they aren't good for much over 500hp and that they're good for much more than that.
Sent from my DROID RAZR using Tapatalk 2
Dirtymaxx03
3,109
a generous dyno, and alot of nitrous waaaay up in the rpm range
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
I would imagine that they just got lucky. Made a pass on the dyno at that hp with no problems but weakened them or bent them... Dmitri Millard did 1799 hp on rods alone in his lb7. Then something went through the block. But that doesn't mean stock internals on an lb7 minus rods are good for 1700 hp...
Andrew
Costly Obsessions
Aug 7, 2013
275
delaware
wow never heard about the 6.7 cummins being weak always figured they followed in the 5.9s foot steps of being pretty tough
Dirtymaxx03
3,109
We are talking about the 6.7 ford.
The 6.7 cummins is not as strong as the 5.9
Seems that once guys go twins and start making big torque down low, the rods cant handle it. Alot of that has to do with the steeper angle the rod is at due to the longer stroke of the 6.7 over the 5.9
'strokeThis_'07
Oct 2, 2009
107
Laramie, WY
Must have been a 6.7 cummins cause as far as i know 5.9's never had VGT's on them.
Correct, 5.9 never did have a VNT, only 6.7
12 and 24v rods are good for north of 1k.
CR rods start getting iffy around 9-1000. Some push them over 1k but it's really only a matter of time before they bend.
6.7 has steeper rod angles than the 5.9, due to the longer stroke. 6.7 rods, I really wouldn't push them more than about 800hp before I went billet. Anything over that, especially running compounds, it's going to get messy and expensive REAL quick.
dirty_max
815
eureka il
im glad we have a cummins guy in here to set us straight :hug:
