stabilitrak (uh-oh!!) and cruise control might not work. And if you have an electric-shift xfer case, 4wd low might not work (no TCM to send a message to the TCSM that trans is in neutral or park). Door locks might go wonky with no P/N status being broadcast by the TCM to the BCM.
Or I guess you could keep the TCM wired in, and IMS logic circuit wires grounded in the proper fashion to fool the TCM into thinking the trans is in park.
You might have to keep the TCM in there anyways though, for the speedometer. I dont know if the LMM ECM cal will accept a variable-reluctance speed sensor reading directly (like on factory 01-06 ZF6 trucks), or if it will only accept the replicated TOSS from the TCM.
You would also need to do a little wiring as far as a neutral safety switch, if your tracks tech inspection requires that.
No reason it couldnt be made to work though, at the expense of some features and minor quirks.
Ben
Oh Ben, you know I would hate to loose my stabilitrak lol. You have made some pretty good points I hadn't thought about. That's why I asked the question.
