Duel CP3s or single nodded CP3
56taskforce
1,089
69
Sorry to hear you are having trouble with them :hug:
I thought dual fuelers where supposed to be so reliable?
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
5
Haha, Thanks man. Got the new lights in.. OP if youre looking for 600hpish Marks modded LBZ pump is what id do, BUT...then again.. I never thought id have a stg2R built trans 100s and dual pumps either lol..Plan Big
CaptPhil
1,012
Delaware
I run very high pressures as well. The only issue with LLY and LB7's is that you cant control (or see for that matter) the pressure once it goes over 26k and some change. My race tunes flatline the pressure sensor at about 30' and stay that way the entire pass. There is a definite and track proven power difference running high pressures.
Made one pass on tune 3 at high pressure, 133mph trap speed. Another pass that night and truck wouldnt hold rail above 23k, but maintained it the whole pass, 123mph. At those speeds and my weight that is nearly a 200hp loss in power, just from rail pressure.
CaptPhil
1,012
Delaware
Pulse width, rail and mm3 Tables stop at 190mpa or ~27,000psi.. How ate you controlling more?
Once you command over the rail pressure sensor's limits, which no matter what dont read over 180mpa, the rail pressure will continue to climb, you just cant see it. So you command 190mpa, set all your limiters above that, and the truck will never actually "see" that pressure. As a result the FPR will continue to open to try and attain 190mpa. The truck doesnt know how much it is making, just that the sensor has stopped at 180mpa. Could be making 220mpa for all I know.:eek:
You command it in the Fuel Pressure Base table, obviously dont want to do it at normal driving mm3.
S Phinney
4,008
Quncy, Fl
Since we are talking about a lot if guys running really high pressures and Mark does a lot of dyno tuning, I have a question for Mark. At what point have you seen on the dyno that more pressure didn't make more hp? I ask because when you add pressure you add heat to the fuel and may make less hp.
663
Exactly anything over 190mpa you are shooting in the dark..
cstephens93
Oct 13, 2014
677
31
Tallahassee, FL
Does this explain why when I log my race tune from ATP, my truck wont make more than 23kpsi actual? Or is this entirely different....?
CaptPhil
1,012
Delaware
No, your truck won't make over 23k either because that is all the pump will support our that is all the tune is commanding.
cstephens93
Oct 13, 2014
677
31
Tallahassee, FL
I never understood that...why write a tune that commands 26kpsi, when the pump only supports 23kpsi.
More reason why I started this thread in the first place
56taskforce
1,089
69
My LBZ goes too 26k seems to hold well but dose drop too 25k at about 3,800 rpm. My top tune runs too 4,100 rpm I don't know if the tuning or something else is the limiting factor. This being said I think my stock pump is in pretty good shape. Exergy recommended either dual fuelers or a modified pump in order to take full advantage of any injector over 30%.
When I contacted Exergy my question involved narrowing pulse widths and increasing reliability on a stock bottom end at around 650 rwhp.
S Phinney
4,008
Quncy, Fl
Your stock pump can support 26k psi. The tune has to be written for that. You do need a lift pump as well to supply your pump fuel. When you log the tune it will tell you what it us commanding and what you are getting. Those numbers match closely or do not match closely. It is typical to be down 2 to 4 thousand psi somewhere along the log. Does it fully recover and desired and actual match? If all us in good shape and it won't recover then you are in a situation where the pump can't fulfill the demand. If you have a log either post it here it you can email it to me to review for you if you would like. I will pm you my email.
Tothemax
xgmtech
Oct 16, 2014
607
new york
Default
IM so dang tired of my dual pumps...i bought them used off some guy on facebook (my mistake) Thinking the controller is on the fritz, Mark and I had issues with rail pressure bouncing and think we got it dialed in then i threw 100s in this weekend and now the top pump makes a knocking noise ...brand new pump last night, still knocking!! Exergy 10mm here i come! If i dont get this fixed.
If I read this right after you put 100 overs in the valley pump started knocking? And you put another new valley pump in and it still knocks? I ask cause I put 60 over and a second lbz cp3 in my truck and I defenatly hear a knock from my original valley pump?
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
5
tothemax, My top pump is knocking. put new pump on last night, still knocking Looks like our trucks are very similar in mods
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
5
Going to update to the above post in case anyone happens to have the same issue, I ended up having the feed and return lines crossed from the filter head to the pumps causing the knocking sound!:roflmao:
