Drop shackles
Pwinland95
93
Illinois
Hey guys I know this subject has probably been beat to death.. I'm new to the forum.. I'm looking to lower my lmm. Gonna order some drop shackles. Any specific brand, I was looking at spring tech on eBay. What do you guys recommend as far as ride quality? Should I go with 2" or 3" or should I remove my overload spring too? I only pull a bass boat don't do any heavy towing. Let's hear some input!
1SloLMM
110
Sioux City, IA
Just get the cheap ones off of ebay, 3 inch, and leave the overloads. My truck hits the axel pretty easily with it in and only a decent load.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
I bought some Crown performance shackles from Ebay, mine flex side-to-side with the 1-1/2" front and rear sway bars I installed several years ago, kinda anticipated it and now need a rear trac-bar.
You'll probably be OK with them towing what you have, anything more you'll most likely hit the bump stops. If you remove the bottom overload plan on installing airbags.
Cheap ones are not option and I think mine border on that and you're asking for a lot flex and who knows what else might happen while towing, just not a good combination...
Front
Rear
Pwinland95
93
Illinois
I plan on doing trac bars at the same time I guess I should have added that. My question is it worth pulling the overload? I just heard it rides better. Or just go with 3" shackles
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
Depends on the shackles, I know the new trucks are a little bit different. But i ran cheap ebay shackles on my crew cab and they had way more holes to adjust the truck at different heights. But it makes them more flexy the good ones corbin bought that are on my reg cab only have 2 hokes it the top and are solid most of the way up and would be way stronger. The cheaper ones were basically 2 long pieces of flat stock going up like 5 inches full of holes. Id go with some good name brand ones especially if you are going to tow
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Track-bar for me in addition to "axle wrap" or "traction bars" or whatever they're called...:thumb:
https://www.google.com/search?q=trac-bar&num=100&newwindow=1&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjjmrTUjc3LAhVC72MKHZZQDMsQ_AUICCgC&biw=800&bih=1157#imgrc=3e7Dtgdxc95r9M%3A
AJH
257
Memphis TN
I vote panhard. Is there enough shit under that axle?
Op I wouldn't pull your overload mine are MIA and I can squat my truck way to easy.
prostreeter600
Street rodder
Jul 18, 2010
893
Dallas Tx
I've always read that your pan hard bar should be parallel with your axle at ride height . That picture shows it on a large angle which would cause the axle to shift more side to side when it suspends up and down . With the bar parallel it minimizes the side to side shift .
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Kinda looks like the truck is on a lift so the suspension is drooped?
Pwinland95
93
Illinois
So guys I finally got my drop shackles. Any help or info for installing them? I'm sure the bolts may be seized in there but what's the easiest way to get the top bolt out?
