Drive pressure Gauge
quadracer37
Mar 31, 2009
547
northern, IL
if thats the case then thats not good is it? how would that happen?
i recently just put a new turbo on, well a very very low hour turbo. when my head gaskets where leaking and i had it all apart for the studs and new gaskets i found out my turbo was not in good shape so i purchased a used one from Tony B. when i got it from him it was pretty much bare, i had to swap over the waste gate and oil lines from my old turbo. there isnt a whole lot to i dont think i could have messed any of that up..
i have a PPE boost valve and i have my boost gauge plumbed into the wastegate line as well. my boost gauge does not fluactate rapidly at all like the DP gauge does.. if that makes any difference...
kenny
kennydiesel
Mar 5, 2009
319
washington state
do your guys drive pressure gauge reading fluctuate quite a bit?
i've got an autometer cobalt 0-60 psi mechanical gauge, and im useing 5ft of coiled 1/4'' copper tubing. gauge is almost impossible to read, when im getting into hard the needle fluctates +- 20 lbs and the needle moves so fast you can hardly see it. (like i'll see a high of 45 or 50 psi, and it will move to as low at 25 or 30 psi, so fast you cant see the needle moving lol)
is this normal for the needle to be fluctating this much? seems like a liquid filled gauge would maybe solve this problem, or is it because im useing a mechanical gauge?
Try adding in a needle valve before the gauge and close it way off (not all the way) to remedy your exhaust pulsing your gauge picks up. Mechanical gauges are a lot more responsive, and will closely mimic these pulses worse than an electrical gauge would.:)
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
I don't think you screwed anything up. I'm not a fan of boost read off the wastegate line though - I like to know what the motor is actually seeing after the intercooler.
I didn't think of this for some reason but yes each time an exhaust valve opens on that bank there will be a spike in pressure that a mechanical gauge will pick up on, especially if you drilled and tapped the manifold in front of an exhaust port.
quadracer37
Mar 31, 2009
547
northern, IL
well that probably explains my problem then, it is drilled and top at the very back of the manifold right out of the rear cylinder on driver side. same spot the hold is tapped for already on a BD manifold. so i will go to the hardware store and get a needle valve and put it inline between the copper and plastic tubing and see what that does.
so you drill/tap the turbo housing for the boost reading instead of putting it inline of wastegate?
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
Okay, I know I'm digging up an old post, but is a drive pressure gauge that helpful on a fixed geometry turbo? Didn't find a direct answer when it was asked earlier.
If so what exactly do I need to hook it up...best location, plumbing, best gauge/readout etc?
Looking at it for more of a cylinder psi/tuning aspect.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Depends on if you tune a lot:) I would get a gauge that is min double the pressure of the turbo or even tripple:eek:
mine comes out of the PS manifold 6" of stainless tubing to a braided hose to the sensor
I use a elctric gaauge from autometer because i like to log the DP instead of trying to watch it
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
Bringing this back to life....:D...... Where did you guys get the braided stainless hose? I was doing some work on my truck the other day and noticed that the copper line that i have now is kind of loose/wobbly in the fitting and I'd like to just swap the whole setup for one of those sweet stainless ones.
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
I dont think teflon lined braided line will last long at 1000*f for long; HOOKED TO THE EXHAUST MANIFOLD
