Doing heads and water pump
S Phinney
4,008
Quncy, Fl
I've used lml gaskets on probably 10 trucks with no issues, one being my personal truck.
However nothing at any "extreme" power level. All stock engine trucks except one and it's still stock fuel with a stage 2 r.
I have used them on my triple truck. No issues holding there. Prep is everything. If something gs not straight it will show it itself.
Harbin_22
3,858
Southern Indiana
So are you saying my prep is what caused mine to fail? How much power does your tripple truck actually make? How many miles of abuse do you have on it? How many passes down the track? What times were they? My block was feshly decked and my heads were too with H11's torqued to 130#'s. 85# boost, 100-120#'s drive, real HP numbers around 1,080-1,100 at the tires.
Harbin_22
3,858
Southern Indiana
My stock headgaskets and headbolts took 65#'s boost and around 750hp for thousands of miles and weren't blown when a rod exited the block. These should not have failed in my engine! Do what ever you all want, but I will not run them again. Not worth $100 you save
S Phinney
4,008
Quncy, Fl
I'm not saying anything except that they held up we'll at over 1000 hp. I don't know why yours failed. I do know that oil contamination or something that isn't straight will not last no matter which gaskets you use.
5,911
well, guess ill cross my fingers the LML's last on mine. this summer will definitely test them...
custom8726
2,784
Upstate N.Y
On a positive note, the set Im putting in now are going in my Regular cab build, so atleast it's not my daily driver if they do fail. Besides I doubt this motor is going to make it a season at the track anyhow. ;)
Feb 17, 2014
62
I did the socket on the flywheel trick and I can't break the nut free. I've broken 4 breaker bars. Snap on breaker bars
Awenta
4,090
CT
I have a 4 ft 1 inch drive bar. Didn't take much effort.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
You should be asking yourself what you have to do to get it back on properly:D
Told ya its a PITA:hug:
YOU NEED A BIG ASS BRAEKER BAR!
AND THEN A PIPE
A NUT SACK FULL OF TESTOSTERONE
AND A LITTLE DOSE OF STUPID STRENGTH
:spit:
FWIW- I snapped the hossle of a 1/2 breaker bar, it wasn't a snap-on or anything but it wasn't a harbor freight quality tool, either...
custom8726
2,784
Upstate N.Y
Pulled 3 balancer bolts off 3 different Duramax's in the last week and a half all with my Milwaukee 18v 1/2 impact. Point being a decent 1/2 drive impact goes along ways, well worth the 20 extra minutes it takes to make the room to use one while pulling it apart with the engine still in the truck.;)
Feb 17, 2014
62
I'll make room to put my air impact on it one of these days I just didn't feel like pulling the radiator today
The Kansan
Aug 30, 2013
179
Topeka, KS
I made this about a year or so ago. Its a 1 inch solid piece of steel 3 feet long with a socket welded to it. It took that and a pipe on it to get mine off.
