does this look like bad motor mounts?
dirty_max
815
eureka il
ok guys, i have been noticing that when i take off from a stop in my truck it feels like there is a lot of unwanted movement up front. it got a lot worse after a rough pull this past weekend. so here is a video of it. the first part is just reving it up a little and the second part is letting the clutch out a little with the brake on. any help is appreciated.
http://www.youtube.com/watch?v=EtIcwqvClE0
dirty_max
815
eureka il
thanks guys. it seemed weird because at the beggining of the summer i clamped my springs, put traction bars on and pulled my t-bar bolts out and didnt really notice it all that much anymore. probably because my clutch felt like it was engaging a whole lot more smooth with the springs clamped. but i returned my suspension to stock today cuz im done pulling for about a month, and i noticed it seems a lot worse. im sure the beating it took this summer didnt help but im still blaming the last pull because it was ridiculous and im still mad about it :roflmao:
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
The rubber in my driverside mount was shot back when we did twins. Josh had a new mount that bolted and installed.
The old mount has a steel lip that will catch if the rubber fails, might as well change it and do it right.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Search Ghetto motor mount fix I can't search from my phone for some reason but I did mine and have had them that way for 5 years and going strong.
550
i used these 1.5"x3" spring eye bushings with 2" .250 walll DOM and 9/16" bolts
mine uses the old clamshell style mounts, the GMT800 style are too tall
5,817
what? never heard of this
lots of guys dont know that cause they have never played with poly mounting motors and such. it will add vibration to the truck, will it bug you? depends. i know it would sure as hell bug me so i bolted mine with a 9/16" grade 8 bolt a long while back. still goin strong
dirty_max
815
eureka il
well dang. too late i already ordered them this morning. but with the way my truck already drives i seriously doubt it will bother me. but i will let you guys know.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Just drill a hole in the mount and put a big grade 8 bolt though it. Costs about $5 and works just as well as the expensive ones. :)
X2 these worked very well for me for years.....only use a grade 12 the grade 8 will stretch
I box welded my motor mounts last time motor was out...but don't recomend for a dd
