I gotta say though, I wouldn't expect cleaning the trans cooler to drop your temps 40-50*, I would think there is something else goin on, also, have you looked into getting bigger trans cooler lines? Alligator diesel sells a set of 5/8" heavy duty trans cooler lines, maybe a set of those would help a little just by being able to move more fluid, just a thought, but again, I wouldn't expect that to drop your temps much either, although I do believe it may help some since you are running a built trans, which typically run a higher line pressure and move the fluid faster. I have a set and an upgraded cooler, and I will only see over 200* when towing 10k.
