Dodge brake conversation
cafryer
May 5, 2011
1,074
Utah
Anyone ever put dodge brakes on their trucks as an upgrade? What's all needed to run the dodge bigger rotors and calipers
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I have the PSC upgraded pump, power steering cooler, Royal Purple fluid, an LML hydrobooster, and my truck stops awesome...
Prior to installing all of that stuff, my brakes were pretty bad. My PS pump was on its way out, my hydrobooster had 235k miles on it, and the fluid was old..
Ben
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Ben
How well did the lml hydroboost bolt up or was there a ton of modification to make it fit
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
100% bolt on.
Im almost positive you'll have to use a 2011 hydroboost unit.
2012+ I believe has a different brake pedal push rod due to the 2012+ trucks having an analog 5v brake pedal position sensor, versus the 2011 and older trucks that have a standard on/off brake pedal switch.
I could be wrong, but just to be sure, I would get a 2011 unit. That is what I used on my 2005 and it was 100% bolt on.
Ben
