exactly, wasnt that long ago everyone said an allison wouldnt go 9s .
Wasn't that long ago that a 10 second truck was a speculation.
But you still have to consider that there used to be a time when a 10 second pass in a duramax was a dream.
Congrats Dimitri!! How about a phone call to me?
Ken the only weight i have of the trucks was my first race in florida, it weighed out at 5600 with me inside, but the same scale was setting crew cabs at 6500 so i believe the weight is off, i have a local scale here in town i will be taking the truck to tonight, i should have an accurate weight soon!If you were to put on a graph how difficult it is to make one of these trucks run in the 8's versus run a high 9 second pass I'd say the line would be pretty much straight up. If it were that easy then there would have been a number of trucks already doing it, so far there have been only 2. Both 12 valve cummins.
So many things have to be right, and a couple of the most important ones are totally out of your control, being track prep and Density Air. There are many trucks currently running that make the HP to do it, it's the weight and setup. I don't know what Dmitri's truck weights but it's over 5000 and less and 6000 I venture. If you do the math it looks like a 5500 lb truck making 1200 hp to the wheels should do it, but it doesn't, being 4x4, air drag and a ton of others things factor into it.
Someone will put a dmax truck that weighs at least 4500 lbs into the 8's it may well be Dmitri, the odds of it be being done with an Allison at least was we know it using a stock TCM is slim to none IMO.
Yes im still on the stock tcm with minor adjustments made to the tunning, i was not even aware there was a stand alone for one are they better simon??If he was running nos it doesn't change anything? It's still Fast!
Congrats
Dimitri are you running the stand alone for your alli? Someone had said u are but I rather Here frOme you
This was a turned down run has it ever ran at it's full potential? Also why is everyone afraid of this guy? Seems like just any other duramax hot rodder with very deep pockets! Seems to me if he didn't want people speculating on his current accomplishments he wouldn't leak info and post himself! Otherwise it comes with the territory.
Dmitri you have done good things for the sport... you set the standard pretty high for the rest....
Thanks for all the hard work and tons of money you spent...:thumb:
