prove it.....just kidding Adam:rofl:
:blowme: see if i help you again
:rofl::hug:
the pipe that my finger is on greg you marked backwards it flows from below the t-stats to the water pump since it dumps out on the suction side of the pump
Geezus! Adam was right two times is one thread?
:rofl::jk::hug:
:rofl::hug:
In the pic, what/why are you referring "It needs air"
LOL thanks for the heads up
that the tire on my Raptor
i may have just saved your life.
Your welcome :cool2:
gm has it poorly worded throughout....
I looked through Service information and found a step by step how to pull something... and it tells you, now pull this, then this and it shows pics of these items. The way the pics are and the way it is described - that is how the coolant flows.
exactly
what was done if anything to the oil cooler?:rofl:
can you guys tell me why i would have overheating issues on a fresh built motor?
here is what ive done
changed thermostat from brand new to brand new
swapped out the new water pump old one was fine
bled air constantly
pressurized coolant to 18 psi and no loss of coolant
eliminated the heat core and looped the 5/8s line
im at a loss
