My .02 in tuning lbz/lmm shift defueling... Does a truck from the GM lot defuel nasty? Negative... So if it doesnt defuel nasty off the lot, then once tuned it does defuel nasty, then i would start back tracking what made it shift bad in the first place. IMO, the shift defuel on these trucks does not need to be tuned.:angel:
Doesn't Rob tune your truck ???
Shift defuel should be set up with the same quality between stock and built trans if you ask me...
Less defuel wont make it shift harder.. Many times it ends up aggravating a problem. I find that factory defuel is plenty quick enough, the trans doesnt have to learn as much, and shift quality is better than those i have rode in that try to fix it. The allison makes shifts by calculated torque, tp, vss, and rpm... It has to be happy with all 4 conditions to make a nice shift. From the factory they do great and in my experience has no gain when being altered besides flares ect. Many folks will say they have "fixed" defuels ect. on the lbz/lmm, but IMO there is no "fix" when they shift great from the factory... Just my .02
i'll try the stock tune again
Ill help you this week, send me a log again and you know the cell
Put a bone stock tune in jake... See if it does dumb stuff stock.. If so then you know u have a hard parts issue... If it doesn't, start bringing in uS and timing in gradually. Do not touch any other tables (yes I know other will need to be modified) this will limit you roughly to 79.7 mm3 so make your truck have whatever uS you want at that mm3 and go from there. This will be a decent diagnosis.
