that doesnt work lighting is 1-2,000lb lighter...
put balast inthe lighting to weight hte same as the LBZ and see what happends.
They would run neck and neck. The Lightning has a supercharged engine with great area under the curve. They trap at ~101mph stock, yet are 2000lb lighter, which lines up well with stock LBZ traps of 86mph ish.
Since this is a tech thread,About cranks, has Any one even atempted to answer the thread starter's questions and replies besides my self.......
How did we get into the physics of HP and TQ......... Did RPM call them out?
cause torque breaks pistons, rods and cranks...
Well, FWIW, if I was going to go through the bother of buying a new crank, I would go with a stroker. The extra swing is an advantage both in torque and chamber pressures at a given fuel delivery.
The torque is obvious from the longer moment arm. The pressures because of the same increased leverage.
Crower Crankshafts are made from the finest quality materials in the world. Our top of the line forged cranks are made from aerospace quality, vacuum degassed 4340 chromoly steel. Our 4340 forged cranks are "non-twist" drop forged for the strongest crankshafts on the market. Crower's billet cranks utilize either 4340 or EN30B materials. It's your choice at Cower, we make what you want and need for your application.
Jeez-o-pete! All the chest thumping about TQ vs. HP is entertaining. Is anyone listening to anyone else, or have personalities gotten in the way and turned this (already way off topic thread) into a "my dix bigger than yours" contest?
There's nothing to argue about. TQ and HP are first cousins. HP is only a mathematical derivative of torque and RPM. No TQ=no HP (or no RPM=no HP too, just to be fair.). As an engine builder, all you have to decide is where in the RPM band you want the torque optimized.
Typically, if a builder wants tons of grunt (a high peak torque number), you will see peak numbers appear in a lower portion of the RPM spectrum. Volumetric efficiency is somewhat simpler to optimize at lower RPM, so peak torque numbers are higher than what you'd see in a similarly prepared high HP engine. GENERALLY speaking these engines lose VE, and thus torque at higher RPM, resulting in ho-hum (relatively speaking) HP numbers. It's a little cliche, but yes, "torque gets it moving".
For the "HP is everything" crowd, well, sure it is. But remember, to get that high HP, you design your build to optimize VE and thus torque at a higher RPM. So in effect, your still building for torque, but at a higher RPM. Now the torque peak numbers you see in these builds is typically less than peak in a grunt motor, because it's tougher to achieve decent VE at higher RPMs. So even though you're not building for bragging rights torque numbers in a high HP build, you are still trying to maintain as high a torque number as possible through a higher, broader portion of the RPM band. To say that torque doesn't matter in a high HP engine is silly. You couldn't show off those high HP dyno sheets without high, sustained torque numbers.
That's why you hear talk about a broad, flat torque curve. Best of both worlds: provide better acceleration from lower vehicle and engine speeds to maximizing vehicle speed (MPH). Any engine which has significant, narrow peaks of either condition (low RPM torque or high RPM horsepower) is gonna be a one trick pony and not fun to drive. Unless of course that's what you want.
So are Crower's cranks drop forged or billet?
Silly rabbits, it's all about torque. Torque at the rear wheels that is. The drive line modifies the engines torque as it shifts through the gears. To maximize the torque at the rear wheels as you go down the track, you want spin the motor faster so you can stay in lower gears. That is, till the torque at the rear wheels drops below what you would make in the next gear at that speed.
Using your dyno chart, you would be looking at the torque numbers for the pre and post shift RPMs to see where you should be shifting.
But what do I know.
At the wheels on a dyno. I don't know what you're getting at with the torque at the wheels thing. Does the RPM where an engine makes torque change when it gets to the wheels?Where are YOU measuring the torque? The only thing that matters is torque at the wheels.
