Crower Billet Crankshaft?
721
Ok, I dynoed my truck on a dynojet acceleration dyno and it showed 1300 ft-lbs of torque at 2200 RPM and 690 HP at 3000 RPM (which equals 1207 ft-lbs of torque) in 5th gear. Are you saying that I would be faster if my truck shifted closer to the peak torque?
I never got an answer to my question either?
you would want you next up shift IE 3-4)to hit close to or just b4 peek tq and ready to shit about peak hp
13,765
834
In my scenario above, what is the best RPM for my truck to shift? I wish my dyno sheet wasn't packed up.
Fingers
Village Idiot
1,719
104
White Oak, PA
OK, let me put this out there using a Dyno chart from my engine a few years ago.
This first graph is of the rear wheel torque that would be produced in each gear. (I had to add some additional data by hand for the higher RPM levels)
attachment.php
This next graph shows the same data but has been adjusted to show the torque at the rear wheels as a function of MPH. I assumed 33" tires. Note how the torque curves intersect. That is where it pays to shift to the next higher gear.
attachment.php
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Fingers stuff is pretty close. Notice the torque is falling the whole time. That's because as soon as you put speed (rpm) into the formula, it becomes HP again. If you started with the HP curve and did the same math (torque at the tires vs. speed), the points would be the same RPM.
Here's what I know from real life drag racing late model cars and trucks:
You are going to shift after the HP peak if RPM limitations don't bite you. Experimentation will be necessary, because doing it on paper only gets you so far. The point falls between the HP peak and the "matching point" on the HP curve.
The matching point is where the HP in the gear you are in (falling), equals the HP in the next gear (rising). I used to think the matching point was always the answer, but it isn't the best. Could be due to tach lag, but it's all you have.
13,765
834
attachment.php
attachment.php
Thank you!
And thank you!
I guess I need to get on a dyno and see what my torque/HP curves look like in each gear.
Fingers
Village Idiot
1,719
104
White Oak, PA
FWIW, I found the G-tech to be a good tool at the track. You can plot acceleration and see how it tapers off. Looking at the shift points, you will want to look at the acceleration before and after the shift. You want at least the same acceleration after a shift.
It is strictly trial and error, but works.
Redbone
but this one goes to 11
May 1, 2008
261
Indy, IN
Where are YOU measuring the torque? The only thing that matters is torque at the wheels.
And as a side note, this what all of this boils down to:
Say at 3000 RPM you are producing 500HP at the flywheel in 4th gear (1:1). This shows the the engine is producing 875 FtLbs (Torque=(HP*5252)/RPM). We're gonna ignore losses in the driveline for this. Going through the differential (say we're using a 4.00:1 ring and pinion), the 875 FtLbs at 3000 RPM gets changed to 3500 FtLbs at 750 RPM at the tires. If you've got 32 inch tall tires (2.67ft diameter or 1.33ft radius), that means you've got 2625 pounds of "push" at the contact point. Force(lbs.)=Torque(FtLbs.)/Distance(Ft.radius)
So the higher in RPM band you can make torque, the more "push" you have at higher wheel speeds. This is why big HP motors show big trap speeds.
