Cranks for 2 seconds and quits
94f450sd
Apr 21, 2018
Yes.5v to cam sensor,which I have.12v to the crank sensor,wich I have.my volts are correct.my grounds are good.i had to swap harnesses so I know the block grounds are good.
I have fluctuating voltage on the signal wires.j don't know what those should be but I assume the sensors are working?
Now I've read a few things that say I should have 12v to both sensors.anybody know what's correct? If I'm supposed to have 12v at the cam sensor but I only got 5,that very well could be the problem.
stibuilder
Oct 17, 2016
239
Snoqualmie, WA
No programming ficm lly injectors.
I have no clue about the LLY's just know thats exactly what they said about the LBZ's in the Kodiak I have 5000$ later and 6 months wasted its what made mine run.
I trust you know more than I do on these things just tossing out my experience. :hug:
Ron Nielson
773
147
Berryton, KS
Yup.i don't know what voltages it's supposed to show but it seems as though the sensors are working
This is for my 2008 LMM:
Crankshaft Sensor - 5V reference circuit
Camshaft Position Sensor - 5V reference circuit
Pin 1 - Sensor signal (Output)
Pin 2 - Low Reference (Ground)
Pin 3 - 5V reference (Input)
You would do yourself a favor if you subscribed to ALLDATADIY or similar. Lots of information makes doing repairs much easier when you have some reference material and don't have to guess.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Here’s a little rant about trying to help people you don’t know... I loaned this guy my spare lly ficm, I even rush shipped it to him because I felt bad he had been having so much trouble. Anyway he pms me that it didn’t work and he was going to send it another shop and let them have a go at it... Apparently that meant my ficm must have gone with it... Any who Merry Christmas Richard Rock I hope you get or got what’s coming to you. If I’m ever in your neck of the woods I’ll look you up;)
