Josh I don't have any pics of the orange and black wire yet
But here is some of the Lenco it's been in/out quite a few times I had to do this to make sure the adapter plate would work as the quick times bell housing was for a small block I had to build a thick palte to compensate for the larger converter.1" thick plate
Also had to. Cut a hole in the floor for the fed/ rev shifter and needed to cut a bit of the tunnel to fit the scs t-case
the duct tape covers the holes for the ACD shift solenoids
Lookin good buddy, i really have to come check this thing out some day soon, if you're ever home lol
Aint that the truth! For someone that works so much he gets alot done on the truck. He must have taught gibson how to turn wrenches
pin 34, C1
I am gonna guess ground it. Do that so you can crank it but you will need to tie it in to the lenco to make the track officials happy.
I started one last year with a zf6 tune and I had to unplug a module under the drivers seat. I forget what it was. I didn't ground anything to get it to fire. The guy pulled the Allison and went to a Dropbox setup with a clutch.
What zf6 OS are you using?
