You use the BD install kit for it right? And I could be way wrong, but are any of the parts in that install kit useful? Most of the direction that I could find for the install of this thing said "use the supplied fitting and hose to connect from the factory oiling position to the top of the turbo"...
Well none of the supplied fittings fit the hole in the block where the factory banjo bolt goes. Also, even if they did, the stock location is a straight thread hole and all of the supplied fittings are pipe thread.
And the 90° elbow that is supposed to go into the top of the turbo doesn't thread in without removing the compressor and turbine housings... it makes it about 2 revolutions and then hits the turbine housing.
I had to go out and buy all new fittings and hose to plumb this thing up myself... kinda chokes me a bit after spending 3700 bons.
My most important question though, hopefully someone can answer... What kind of stainless does HTT use for their stainless turbine housings?
