after I hold down the up arrow and all lights illuminate within a few seconds they all shut off normal?
when your copilot is on Race Mode does it shift different at light throttle?sounds normal to me.
Sounds totally normal to me. Anytime you change settings, the LEDs will light up for just a couple of seconds to show the setting, and then they go into a sort of boost gauge mode where they will light up progressively as boost comes up.
edit: Is it locking the converter???
hmm, i havent really just driven it around in race mod. i know it shifts more firm when on the upper levels but thats just the high line pressure. If you want me to go out and drive around just let me know what you want me to try and i can let you know the result.
Just go out and hammer on it. When the green light comes on, the co-pilot is commanding TCC lockup. If it locks, it is working :thumb:not sure... im not sure the co-pilot is working as i increase the shift firmness the shifts don't seem any different than before?
I'm not sure. I think I bought it in 2007. I'll see what I can find on ATS's website.what generation controller do you have? Im pretty sure i have never seen a green light?? mine is the 3rd gen fwiw..
if you don't mind that would be awesome... i didn't do anything internal to the trans ie Solenoid block or internal harness so maybe i won't feel a shift difference?
Nick will only notice the lock up. He will not notice Anything from the lights being set at 123 or 4 he needs to hold it til it locks in race mod then go out and make a pass and see if it locks up.
