Copilot Settings
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Nick, do your led's light from left to right as boost increases? If so, it should be increasing lockup firmness depending on how many lights are on. If not, check your boost sensor wire, I think it's the center wire on the sensor being tapped. I can check later though if you need. I ask because in race mode, on my truck, it locks some what soft until more boost is indicated.
paint94979
Beer Nazi
Sep 18, 2006
11,715
Around 1/2 throttle or so the far left light comes on then after any more throttle all the way up to WOT no more lights illuminate? all connections seem to be secured correctly
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Nick will only notice the lock up. He will not notice Anything from the lights being set at 123 or 4 he needs to hold it til it locks in race mod then go out and make a pass and see if it locks up.
X2 without the soleniod it will shift the same which might be better as there should be no way a tie up should happen.
paint94979
Beer Nazi
Sep 18, 2006
11,715
finally got this thing to lockup in 2nd... the MAP connection was oxidized on the quick connect was only getting .01v's to the co-pilot wire... now all 4 lights illuminate and the green lockup LED now illuminates. :D
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Does that meen that was your problem all along ? With the other box too ?
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I was driving around tonight and realized my lock up light only illuminates if I hammer it from 50ish mph? Anybody else notice that too? If I get on it from about 35 the blue lights start climbing but it very rarely lights up the green light..
