Coolant/PS fluid/brake fluid flush
zakkb787
<that’s not me...
Sep 29, 2014
2,340
52
Granite Falls NC
Hey guys. Been reading up on advantages of doing PS and brake fluid flushes. Am I limited to only being able to go to a dealership to get this done? I know most of you are anywhere near close to my area but does anybody by chance know of a shop so I can get all this done at? My coolant is still sexy cool and it's starting to look muddy and I'd really like to get it all flushed and cleaned out and get new put in. And my power steering and brakes have been feeling a little different lately so I'd really like to get those flushed with New at it at 265,000 miles anyway. Thanks in advance.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
52
Granite Falls NC
Just called a shop that said they could do it BUT they don't have the machine. It'll be the old fashioned way. Said about $250 range including fluids. This good? Or is the machine that much better
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I do all the above without a machine. If you know what your doing, and how to properly do it I see no reason why manually flushing the items you listed wouldn't be as good as with a machine. I think $250 sounds reasonable.
bigfoot2222
Newbie
Mar 23, 2015
Sykesville, Maryland
For the Powersteering fluid flush, you take the low pressure side off the hydro boost then run some hose into a catch can.
Turning the wheel and hitting the brakes will shoot the fluid out.
I can't remember where there is a how to written, here or DP, but it is pretty simple.
Curtis
Dozerboy
4,892
470
TX of course
Didn’t you want to sell your truck? Man it easy to do it yourself, but $250 isn’t a bad price.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
52
Granite Falls NC
I did want to sell but I keep talking myself out of it. Either way I'd need to buy something to drive that's reliable and it's hard to do that for what I owe in this truck. So just gonna ride it out. Plus I'm attached. So I may do the power steering myself. What about brakes tho?
Thank you guys for all the replies. Helps a ton!! The price isn't bad. He said $59 an hour and about 3 hours plus fluids. Also gonna have my AC system flushed for my new compressor kit and an alignment maybe. Really want to do new UCA and Lower ball joints and shocks first tho. It's not wearing the tires unevenly but I've adjusted it so much it worries me.
torqued2dmax
646
Brookville, PA
Thats why its called Power steering and Hydro boost flush ! It dose both in 15 min , then if you have not bled the brake lines lately its another 15 min , unless the bleeders are frozen in rust , then let the fun begin !
J_Stone06
Wasn't me...🥴
Oct 13, 2012
347
Nowhere, KS
My kryptonite UCA/front end kit has been pretty reliable. I can't really complain too much. My endlinks and tierods were shot at about 75k miles on the truck. Some of the factory stuff is straight crap...
Sent from my SM-G928V using Tapatalk
zakkb787
<that’s not me...
Sep 29, 2014
2,340
52
Granite Falls NC
I've got xd tie rods already and I don't think the kryptonite stuff would work well for my setup really. I'm lowered not lifted. And their UCA are more for leveled trucks from what I've seen.
J_Stone06
Wasn't me...🥴
Oct 13, 2012
347
Nowhere, KS
Yeah, that's true. Centerlink is pretty massive too. To each their own I suppose.
5,836
If the parts show no wear/give, you’re just throwing money out the door. Better off inspecting it first
zakkb787
<that’s not me...
Sep 29, 2014
2,340
52
Granite Falls NC
That's the goal. Already had one ball joint go and it was BAD if you remember. Just don't want to get it all lined up and have another go bad and throw it out of whack. Plus pretty sure they're the factory style. So no retaining clip. But good advice as always! Thanks James!
5,836
No prob. Just check the front end over every oil change. I do that on mine all the time. Helps keep everything in check and see what is starting to go. Then there are no surprises. I don’t believe in the “if one side is bad, so is the other so I’ll replace both” theory. Sometimes that’s right and sometimes it ain’t the case. I’ve seen ball joints outlast the opposite side by 100k or a wheel bearing go another 50k over the previous side. My own truck has shown it too. I just realize my idler arm almost has 100k on it! Pitman was replaced about 30-40k ago.
AZlml
278
32
Goodyear, AZ
You'll be glad you flushed brakes and PS. Did mine at 100k and it was a noticeable difference. Buy the big bottle of brake fluid and suck out what's in the reservoir and fill it up. If you don't have a way to bleed them with suction through the bleeder just grab a person to pump them and bleed them like normal. Start at the farthest wheel from the reservoir. I had my rotors turned and scuffed up my pads and it feels like brand new brakes.
Novak
SQUIRREL TRYN TO GET A NUT
Jun 15, 2015
990
Cloud 9, IDAHO
Kyrptonite is built for all set ups lifted or lowered a AS LONG AS your "centerlink is in the stock position"
I ran mine on my 6" lift and then now factory height with the bars turned down.
Novak
Jun 15, 2015
990
Cloud 9, IDAHO
Kinda like dual batteries. One battery just lets the cold holiday season get the best of them
Novak
Jun 15, 2015
990
Cloud 9, IDAHO
$250 isn't bad
Like my Dad said, when you pay people to do stuff you can do yourself it isn't just how much is your project worth to you but it's also how much is your time worth to you.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
52
Granite Falls NC
I completely agree with you in that. That only reason I'm considering doing them all is because the mileage and I don't know the history of the truck before 248k. Plus when I got the truck the torsion bars were maxed out. And I've had it raised and lowered so many times I'm sure I haven't helped lol.
