Most setrab coolers are completely inadequate for your 15 gpm engine oil flow needs. Only one of them will stay unrestricted, it has 72 rows. I don't know what series you are using though. Just trying to help.
No. The sensor for gauge pressure is downstream, so it won't be picked up.
I'm not a hater, or anything like that...just spouting off what I became aware of when I spec'd an oil cooler for this truck.
I also found that a stock truck, running 15W-40 in the winter, 30 degree morning, had nearly zero filtration flow until the oil got warmed up...all was in bypass. An irrelevant factoid.
