converter?
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
im 500hp stock turbo with the 1057, worked great until i had problems. I would definitely check with mike and see what he is coming up with from Precision. -Jeff
racinmike77
Sep 14, 2008
1,029
MD
im gonna leave this for mike but a 1057 is probibly a little tight for 35s. He may reccomend a 1055 but I wouldnt rule out a 1056 either.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
35's are going to make a tight converter looser and a loose converter even looser .
and to the OP let your trans guy help choose your converter . what your doing, hp, turbo, elevation , and personal preference will play the big role .
radvans
242
SoCal
I run a 1057 but have 4.11 gears...that is what Mike spec'd for me...but at the time it was the latest and greatest.
country boy
Get Some Performance
May 13, 2009
11
Florida
call greg at fti converters and tell him jimmy sent you tell him what u want he will build it or call dan at pro trans of central florida tell him the same they work at the same shop
camcojb
Dec 10, 2007
116
i go the 1058 and it feels pretty good, dont you want a higher stall with larger tires?
I disagree i would not go with a 58 at all
I also would not recommend a 1058 for anything that will drag race. Works great everywhere else, but has more slip than the tcm allows to command lockup. On mine it waits until 4th to command the lockup which hurts the et.
It will lock 2nd on if you do an un-boosted launch, but not with a 15-22 psi launch, way more boost/power/torque and slippage at the 1-2 upshift so no lockup command. It is something that can be tuned out of EFI Live can locate the proper table(s), but until they do it's smarter to stick with something that's proven to work.
Jody
S Phinney
4,008
Quncy, Fl
I run a 1056 with my setup but I could actually use a little looser convertor. Tuning will be the determining factor of how well you like it and how it will perform. Suncoast will make a custom stall for you though.
Durasizzle
Oct 3, 2008
134
Stony Plain. Alberta
i dont drag my truck i mostly just drive around town and do lots and lots of highway driving. but doesnt gearing and tire size also affect how the converter willl "feel"? i dont know much about selecting a converter
slowlmm
Mar 2, 2008
2,582
45
so cal
I told you not to buy it.:baby:
ugh if you say so. u dint have a problem takeing my money and installing it. and then giving me the run around for a year on it telling me it was tuneing spin ons my new motor ect ect. to saying you would replace it. then to going back on your word and telling me tough $^#&*@^@&. to telling me deal with suncoast direct. whos the :baby: now
15,681
Arguing with you will not do any good. Truth is you have screwed everyone you dealt with in SoCal and across the country. I will let people believe what they want. We are all glad we're done with you.
slowlmm
Mar 2, 2008
2,582
45
so cal
Well if you say so. bottom line your opnions on what you think you know of those 2 situations dosent even pertain to this. i guess your warranty should state only valid if i still like you. if not tough shit. you continue to derail the subject because you know the converter is a pos thts why you strung me along for a year. you said you would replace it replace it. you replaced other peoples? i even told you if you replaced it and it dint fix the problem i would pay for the new converter and labor. but you allready know the outcome.
ok now continue to bash me and change the subject
15,681
Sorry Tommy; you and your truck are no longer welcome in my shop.
slowlmm
Mar 2, 2008
2,582
45
so cal
That still dosent answer why you wont replace it? after you said you would twice in pms once in public fourm on this board. or why you wont stand behind your warranty? if you dont want me in your shop fine send me a converter Ill put it in my self since you never charged me for labor to put my 58 in. and I will give you this pos back. Funny how me and you never had one issue not one untill i defended nick then you turn to bashing me. I meen i never evevn asked you for the $285 i paid for your moveing trucks to move your shop. remeber that? But yea im the bad guy here. I have herd from many others with the same issues. on this same thing. but hey must be my spin on right ? or my tune ? or mabey my motor build some how ?
