converter lockup
1chevy02
Jun 23, 2009
504
talked to brayden today and he said that his box will in fact lock any torque converter if three paramaters are met over 18mph, over 15 psi boost, and 100% throttle sounds like a pretty neat deal. He said its the same box as his turbobrake but i have never seen one anyone have one or pics. Does anyone have an allylocker or feedback on one? Where does it tie into?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I really wish brayden would sell it separately without the turbobrake. I have no use/dont want a turbobrake, and I assume he could sell it cheaper as a lockup controller alone...
1chevy02
Jun 23, 2009
504
he does sell it separately as i understood its just in the same "box" for lack of a better word
beach_33
704
des moines, IA
i wonder if you hve a turbo brake and just want the alli locker function of it if you could some how make that work. i have a turbo brake but dont really ever use it but i would still like the converter locker
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
Umm.. Push the button called performance right next to the turbobrake button... ;) You've had that feature for over a year and haven't used it yet !
PS.. Call the shop..
13,735
804
The only thing that would make the AllyLocker better is if it wasn't in that huge TurboBrake box. Is there any way to shrink it down so it can be hidden easier?
beach_33
704
des moines, IA
well i know that i have had that feature but i would like to just use the lockup feature and not the not have the vane control that the turbobrake has. i will give you a call
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
x2!!!
I like my cubby for putting stuff there. I also have some switches mounted on the "roof" of the cubby, so Id rather not lose it.
1chevy02
Jun 23, 2009
504
anyone running an allylocker lets hear some feedback I think we'll try one I'll let you all know how it works
S Phinney
4,008
Quncy, Fl
I have one and it works as advertised. It is a tool that you will only use in racing or sled pulling etc. Its not something you would use to just drive around. You should be able to pick up at least two tenths in the 1/4 if you have a problem with the t/c locking. It is useful for high hp Dmaxes. If you have a problem you will be pleased with it function.
1chevy02
Jun 23, 2009
504
found out something strange that if i shift it on the selector it will lock up every time I guess just that little extra time it lags in the last gear gives it enough time to lock up and if it locks up in 3rd the it will lock in every gear
"I have one and it works as advertised. It is a tool that you will only use in racing or sled pulling etc. Its not something you would use to just drive around. You should be able to pick up at least two tenths in the 1/4 if you have a problem with the t/c locking. It is useful for high hp Dmaxes. If you have a problem you will be pleased with it" function.
thanks thats what i was hoping I could gain cuz 12's here we come:D
15,681
It's a pressure problem, not a slip problem. Fueling in the wrong place will cause this also.
Randy5.0
MAKE IT 3 YDS MF
Sep 7, 2008
292
Damn:eek:, I was convinced it was a tcm/programming issue until you said that. What is the pressure problem then? Guy's without lock up really want to know.
