i'm having problems locking up converter in 3rd and 4th gear on my bigger tunes never messed with tranny tunes. I kinda looked at them and i dont really know where to start. Do i just command it in the charts or is there something to watch out for
ya, tcc lock up. WOT tables and part throttle shift tables. adjust to vehicle speed.
paint94979 said:there is a known lockup problem with certain Suncoast Converters.
:beatdeadhorse:
WHY do people continue to bash Suncoast blaming their converters for programming in the TCM that's inhibiting lockup?????? Even the "wonderful" 5-star has been reported as having that issue without the Co-Pilot. The problem ISN'T that the converter isn't locking up, it's that the TCM ISN'T COMMANDING IT.
Disclaimer: I do not have a suncoast converter, just calling it as I see it.
Excuse me? Just because you have a SC trans and converter doesn't mean you are unable to bash part of it. My point is, by saying "there is a known lockup problem with certain Suncoast Converters" is badmouthing or bashing them for an issue that isn't entirely of their making; As I said, it has been reported that the 5-star has the same issue without the Co-pilot, but Suncoast is the only name that keeps coming up. A more accurate statement that can cover converters from all manufacturers that have the issue (ANY converter from ANY manufacturer that's "loose enough" can have the issue) would be "there is a known interaction between certain converters and the TCM that causes the TCM to inhibit or delay lockup." Your post may not have been "Bashing", per-se, but it was defintely negative press.
1chevy02, fill out your sig with your truck's specs so we can see what you have and get an idea if your problem may be related to the converter/TCM interaction or something else.
Edit: It does sound like you're having that interaction issue; Unfortunately, there's not much that can be done besides getting an ATS Co-Pilot, Brayden's Lockup Controller, or a tighter converter.
In normal drive it isn't suppose to lock until fifth gear. There isn't a problem then as to how you are stating the problem.
If accelerate gently up to 30 mph with t/h and it locks then hammer down it will lock nicely in all the gears. Without t/h or from a dead stop on a 500ish rwhp tune if you hold it down no lockup till you exceed 70 mph.
Would it work to copy and paste tables 5010 through 5013 (tcc apply tables) t/h into the regular mode and leave the release the same.
It only does it certain times and i've never messed with trans tuning and am a little nervous. Do the lockup switches help?
If you had a suncoast converter and made over 600hp then maybe you would have more insight on the situation
Ben...so what we need to do is ask efi to find the tables for us so we can ourselves tune it so we can have lockup right? The table must exsist it's just a matter of having it.I know that....thats the problem that everyone has...
no...that doesnt work. There is an additional "override" table that dictates if turbine vs. input speed difference (slip) is over 600rpm, the TCM will not lock the converter. It doesnt care if D5010 and D5013 are set to 2mph or 200mph, if tcc slip rpm is over 600, its NOT going to lock.
welcome to the wonderful world of the stupid allison tcm. Do lockup switches work? Yes. But they are 400 dollars...
ben
I'll go beg too!correct Steve.
Ive brought it up every couple of months for the past few years, but in reality the EFILive crew is too busy. Its not a big deal for me now, I havent been to the track in almost 4 years and have kind of given up on competition stuff.
If I ever get back into it ill either just buy brayden's lockup controller or start begging the efilive crew again.
of course with my luck ill drop $$$$$ on brayden's lockup controller, then efilive will find the table, making brayden's lockup controller obsolete and therefore not worth anything as far as resale.
ben
