converter bolts
2wd_Sled_Puller
Heavy Equiment mechanic
Feb 19, 2008
1,356
Florida
Mike what should i do about this situation i dont wanna put a new flexplate in AGAIN. BTW thank you for helping me out on the phone. Tranny No longer leaks.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Kurt something else is making the flexplate break. My stock original one has almost 100k miles on it and a built motor/twins, with zero problems.
Are the dowel pins still in place?
ben
2wd_Sled_Puller
Feb 19, 2008
1,356
Florida
ben
Yes ben and it was torque down with a torque wrench. I also went around it 5 times to be sure they where at the right torque. I torqued them to 100 foot pounds this time rather then 8 like i think they called for. And went in a star pattern. My converter bolts is my biggest concern right now. I think when i get a smoother shift my flex plate will be fine
13,735
804
Why don't you follow the correct torquing procedures? (FYI, you can pick up a torque angle meter from Auto Zone for $10)
For one thing you need to replace those 14mm hex bolt that hold the flex plate on and tq is very high on those bolts
Flywheel Bolt - Angular Tightening Method
1st Step 58 lb ft
2nd Step 60 degrees
3rd Step 60 degrees
ripmf666
15,123
14
47
Wentzville Mo
X2 Josh I was going to post the same thing thought I posted the right specs before hand about this.I can tell you that after the 58 lb ft and 2 60deg turns its alot more then 100 lbs
Jun 28, 2007
3,259
NE Pa
Some how some way the bolt missed the flywheel. The may my luck has been going latly i figured it would eat the bellhousing and chew threw the flywheel. Im just glad the good lord has been with me so far on this ol girl. 5 is all thats holding it in. Im trying to get it to shift easyier i think that will help also. It will be a couple months before i take snowflake to suncoast. But now thats shes mine im starting with the build tranny:D
This is one of those things that make you wonder why a stupid little bolt can create so much work:mad: But thats what it should do.....create work, not an I'll try it on 5 bolts additude:confused: Please do the right thing and fix it the right way. If you insist on not fixing it till you do the trans...then DONT drive it till you do the trans. Pretty basic stuff. I know ssome people that opperate with the additude you have, but they have next to unlimited budgets;)And they runn stuff like that risking blowing it up just so they can make one race and do one thing.....thats not how they build their stuff
2wd_Sled_Puller
Feb 19, 2008
1,356
Florida
I pulled the starter off again yesterday. put lock tight on the nut fired the truck up went about 15 miles and the bolt backed off again i torqued it to 130 ft pounds. Sorry guys that 6 bolt is not going in
05maxlly
need used tires
Jan 27, 2008
194
powhatan, va
i ran my truck for a while like 6 months with only 5 bolts holding did many passes on drag strip running a pumped up mcrat tune with no isses i finally pulled out the trans and fixed the issue and dident see any problems but i may be lucky
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Wouldnt that put you slightly off balance also
Is the hole stripped or what? there is obviously a reason it's coming out
useing new bolts?
3,259
NE Pa
Simon I dont think anyone was being serious about actually welding a lug onto the converter. :)
ben
In all seriousness you could do this....I wouldn't recomend it to anyone but I have cut several converters appart to clean them out and then welded them back together. You can do it but you have to have some kind of clue what your doing:baby:
