I'm looking on input on things to consider, I don't want to be stuck on the side of the road late to work or get out in the morning and not make it. I'm not fully sold on the idea yet.
For the first time in 7 or so years I have found myself at a job that does not provide a truck. So, I'm looking into my options for a daily. Commute is only 50 miles round trip, and I'll likely only be doing it for 1-1.5 years before I have a company truck again.
I'd rather not have a payment, but if I did it would be for a small amount and I'd get a GMT800 1/2 ton.
Then I was thinking... I've got my 350k mile LB7 project sitting idle... why not just dump some money into that and DD it? I bought it for a project, only put maybe 1200 miles on it, and only 20 or less since the stuff below.
It's an 02 LB7 ZF6 manual window/doors/rubber floor truck, I've already put in:
Reman trans
NewSouthbend dual disk organic clutch
New NP271 t-case
Rebuilt and shortened the two piece drive shaft (no front shaft yet)
New AC delco motor mounts/trans mount
New AC Delco FPR
New Optima Yellow Tops
New AC Delco water pump, thermostats, and harmonic balancer
Newer better condition seats, dash panels, and steering wheel
I'm thinking I could do:
SAC00's
Kennedy pump
DmaxStore Stg 2 steering kit w/ idler pivot
New 35's (on 17 steelies I have sitting)
Maybe head studs and head gaskets while I'm there
Get rid of the cali egr
4" exhaust
Maybe a new AC Delco radiator, window tint, and an 03+ grill and bumper?
Sounds like maybe $6k in parts to get this thing back on the road?
I'm not as worried about the chassis as I am the lb7 and electrical part. I'll pull the rear diff cover and check the front wheel bearings.
How do I check if the turbo is bad?
I think before starting anything I'd do a compression check to see if I've got blow by and the short block needed work.
Should I be worried about the engine wiring harness? When I did the FPR I noticed some of the loom wrap and raceways are broken so wires are a bit free'er than they should be.
What else am I missing that is likely to shut me down on an old ass LB7?
Reman trans
New NP271 t-case
New AC Delco FPR
SAC00's
Kennedy pump
4" exhaust
