Compressor Efficiency Problem
Lennart
Not from here !
Aug 10, 2006
310
Detmold, Germany
I'll be in frankfurt on the 13th Lennart!! And I've been on the autobahn - in a Porshe Cayenne no less!! Good Times!! At least truck drivers there no what lane to stay in. You should see Moscow though!!
I see, a Porsche on the Autobahn will definately offset you SOTP-Meter ! How long will you be staying in Frankfurt?
Killerbee
Got Honey?
Illustration of what I found to improve performance.
At all costs, air should not exceed 300 ft/s. I prefer 280 ft/s. It's not a magic number, but something to strive for. Above this, the resistance to flow quickly goes ballistic, decaying exponentially. The sharp bend makes this yet more critical. Here are some actual numbers, 700 cfm represents stock airflow.
That bend restricts diameter down to 2.4". By tooling like in the photo, you can make more like 2.6-2.7" effectively.
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
when you can see through it, you've gone to far! :eek::D
when you say inverted you mean it actually goes inside? and makes the bend almost smooth?
Almost filled up both inlet tubes, but not completely, I'm still working on removing material and smoothing the flow
Ruralgas
Nov 23, 2007
9
Hello Killerbee:
Thank you and everyone else for the very informative article.
Looking at the picture of the compressor tube that has had material removed to straighten out air flow, how much of a reduction in compressor/air heat would you expect to see with this much smoother flow?
I don't have access to flow meters or a flow bench, however the pictures and the informative articles are very helpfull and interesting.
My truck is a stock LLY 3500 series with an Edge with Attitude, EGR blocked and a sealed cold air intake which I use for towing a large 5th wheeel RV.
Anything that a person can do within reason to improve air and hopefully reduce temperatures will be a benefit.
Thank you to everyone and please keep the information flowing.
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
Larry, what is the material in the ports? I went back and ran some numbers on those ports as branch T's with no flow. It looks like 10% of the total loss would be found there. About .5-.7 psi at 67 lb/min (hot tune).
So far, I have fully plugged the pcv inlet with a milled piece of aluminum bar stock, the resonatar tube was plugged with an inverted pvc cap, both pressed in. Hopefully this smoothes out the air flow a little.
Killerbee
Got Honey?
a significant amount, a 30 degree COT decrease at WOT, 50 lb/hr airflow (stock). That is approx 22,000 BTU/hr decrease.
There is a 2-4 psi exhaust manifold drive pressure decrease, and 50-100 lower EGT. MAF increases 7% also. Free air.
There should be some much larger gains with the redesign.
Side note, was looking at the neighbors CTD, his mouthpiece has twice the x-section, with a similar close bend.
9,906
152
I'll only be there for about 5 hours Lennart from about 8AM to 12ish- Just passing through on my way home from Russia! If your around there in the morning, maybe I can sneak through customs for a couple hours!!
That is a huge gain in heat KB - 22 000BTU is alot!! I imagine my LBZ could probably benefit a little from the same modifications as well. So there is an advantage to plugging those holes.
It seems Simon was partly right in removing the resonator over a year ago!!:eek:
I can't believe I just typed that!!;)
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
more pics after several hours of removing material:D
Killerbee
Got Honey?
area to roundover
hope this helps
attachment.php
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
Do you have some comparison pictures Larry? Did you get a chance to take some pictures of the stock inlet vs. the one you've worked so hard on?
KB posted a before and after pic a few posts back that are pretty much identicle to mine. As soon as I pulled the old one from my motor, the new one went one, you know my track record with open holes in the motor ;), so I didnt bother to take side by side pics.
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
The log I ran with the new inlet shows approximate 8 - 10 lbs more air than before on a WOT run........Mike will be posting the before and after logs since i don't know how :baby:
Seems like this was a good mod to do, and a really easy one at that as long as you take your time and dont remove too much material rendering your stock inlet unuseable ;)
Killerbee
Got Honey?
Here is Larry's data. I found sections to average that have the same approx rpm and boost, in order to compare MAF numbers. 61.5 lb/min vs 52.9 lb/min (stock). But note the air density is a little different on each, with IAT not held constant. This deemphasizes the disparity. The actual improvement, after correcting for ambient temp differences is probably closer to 5 lb/min. But hey, that is still 10% more air for free. It is consistent with what I am seeing. I am estimating that a redesigned mouthpiece will go 20% minimum.
That is the same as a new $2500 turbo. :eek:
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
I would like to add that this improvement is made with the same fueling, no extra fuel has been added just yet. More tests to come, I'll look back for some logs that show closer IAT's. Thanks Larry for giving this a shot.
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
The screen shots above are not really comparable, in the 2nd screen shot where the improvement can be seen, the screen shot is too far into the log and actually of one of the dsp tunes........I did an initial WOT with the base tune then several other smaller runs "not from a stop" in varias dsp tunes to see the difference while driving.
To compare apples to apples I think we need to compare the log from the start of the run since the other screen shot is of the base tune in question. Just from a quick glance at the 2nd screen shot, that is actually my smoke tune on the dsp switch.
Killerbee
Got Honey?
I don't really feel that it matters Larry. If MAP and RPM (and IAT) are the same, then MAF can be directly compared.
It is by no means scientific, with all the changing parameters, shifting, etc but it is very obvious to me now. This piece, all by itself, completely dogs the VGT and the LLY.
